QUOTE(9146986 @ Dec 27 2007, 06:31 AM)
The factory method uses a closed cell foam gasket over the tube for the oil filler neck and breather tube. These compress to seal around the two upper holes. There is a rubber boot with O ring for the filter console, and a flat rubber washer for the lower oil line connection. IIRC all the boots and gasket stuff runs around $90. I wouldn't install that tank without the filter console boot and clip. The others you could improvise.
If you drive your car around at all in the rain you'll get a bunch of dirt around the fittings and filter over time. Makes a mess of things. I trimmed down a 911 gasket and it seems to have worked really well. I drive mine daily.
