QUOTE(dfwteenerpr @ Dec 27 2007, 07:55 AM)
I've got a trans that I got some time ago that I have always assumed was bad for some reason> well now I need it and want to know if there's some checks I can do before I install it to determine whether it's going to work or not.
It's hard to tell sometimes until they are in the car.
pull the drain plug and take a look at the back side of it. There is a magnet that will collect all the metal filings or any big chunks. Take a look at the fluid and you can even pour it over a car speaker magnet to see what collects.
This sometimes will NOT be a tell tail sign. I did all these things and they all looked good UNTIL I ran my finger in the drain hole and found a big broken piece of metal. It turned out to be a piece of the pinion gear.
take a flashlite and look inside the drain hole for any large broken peices.
Pull the tail cover and check 1st gear for wear. It's easy to do and, if it's bad, fix it. That will save you greif in the long run.
You can get a gasket kit and replace all the seals, it won't hurt.
There are aricles in the classics thread on how to take the tranny's apart if your inclined to do so.
Good luck
