Ok, need some advice from all you guru's. Since I have the engine out now, I figured that I should pretty much go through those items that have a tendency to go on an engine. (even though the PO had just gone through the engine before the fire) So what I want to know is what do I need to do?? Do I replace all of the gaskets and seals?? Which ones should I do?? Anything else I should check while it's out??? Do I just leave it alone?? Where is the best place to get the gaskets?? Is there such a beast as a full gasket kit that has all the gaskets I need for my 1.8??
Thanks in advance for your help!!
Ron
