What would cause all four injectors to constantly buzz at a high rate of speed when you turn the key on, but without the engine running? It's way faster than when you hit the butterfly with the key turned to the on postion. It doesn't happen all the time either.
I got it fired up and then suddenly it started to bog then clear up and run fine and then bog again.
Now it's just flooded so bad I had to quit for the night.
When it does happen the injectors will all in unison buzz very fast as long as I leave the key on. It's not the fuel pump because I pulled the plug on the injectors to make sure.
It just started after I pulled the engine to fix some leaks. So it's something I did, but I made sure to mark everything before I pulled it apart. I'm thinking that this old harness finally broke somewhere maybe?
If I can't figure it out I'm going to try another harness that I have and see what happens.
Any ideas?
