QUOTE(Mark Garriott @ Dec 30 2007, 10:47 PM)
Look beautiful, but if the ear is 1/4" thick, and trailing arm has roller bearings, how is toe and camber adjusted?
Mark brings up a valid point. There is enough slop in bearing set-up (in and out) to allow for it. The is washer not parallel to the bushing face. The result is uneven wear on the inner washer.....which was apparent with the original ear.
The alignment guy was cussing at it last season....I don't suppose I've made it any easier. I run -.5 camber & 0 toe. Were I going for -2 or thereabouts, we could have a problem.
