If it was me.
I would run
THIS ELECTRIC PUMP Before I would run a Meziere pump.
These pumps run longer. More GPMs and are trick as shit.
We ran one a BIG 528 CI BB Chev. in a 55 tubbed Chebby.
Had the Meziere in the first incarnation. And the sucker would overheat on the road.
We plumbed in the Davies pump with the beta iteration of the micro processor control unit.
And the problem went away instantly. That was 2 years ago... And the owner hasn't changed the pump yet. Its a nice piece.
We also eventually changed out the anti-freeze/water coolant for
FOR THIS coolant.
This particular coolant has dam near zero expansion. You could run it without a radiator cap at max load and it won't boil. Hell.... You could stuff a rag in the radiator cap flange and it still won't boil out.... very Kewl.....
This stuff is simply trick.. AND expensive. As ya get what ya pay for...........
The combo of two items above. Would be my best case scenario.
ALSO.... The Mezire pumps weren't made for Synth coolant. At least they used to built that way.
And unless something changes.
Your stuck with regular coolant and water. NO Synth additives. (No water wetter)
The above is simply another option that is worth looking at.
Cheers,
Clayton
