QUOTE(Red-Beard @ Jan 7 2004, 03:41 PM)
Are they similar to the ones for the mechanical/hydraulic?
i'm sorry, "they" which what ?
IMO, "mechanical" should not be used in conjunction with 'chain tensioner' unless you're describing a non-factory replacement part which is JUST a spring. i wish i could find a picture of one of those abominations... but they're just spring cartridges that install into the body of a hydraulic tensioner (like the picture RedBeard and i included).
Porsche has *always* used hydraulic chain tensioners. they changed a few times over the years but they are *always* hydraulically damped.
the pressure-fed "Carrera" chain tensioner is hydraulic but it obtains oil from the gallery instead of relying solely on an internal reservoir.
the picture RedBeard posted of a factory hydraulically damped chain tensioner is shown with a "tensioner guard" installed.
the clamp-on-the shaft tensioner guards work with the factory hydraulic chain tensioners. they do not work with the pressure-fed "Carrera" tensioners...
i am trying to be as clear as possible about this confusing topic because these parts are hard to work with considering the very substantial spring tensions involved. the car is out of service once you get into the chain ramp area, and if you screw up the tensioner rebuild/install/whatever your valves will get (too) friendly with your pistons and you will be unhappy. and poor.
there are little holder gizmos (just a very strong 'C' shaped metal piece) that hold the compressed tensioner after it's been compressed in a vise or an arbor press until it can be installed in the engine.
so if i am not being clear on any of this, please let me know exactly what is not clear and i'll try to explain it more clearly. frankly - if you have a 6-cylinder car, you should be reading up on this topic in Bruce Anderson's and Pelican Wayne's books...
okay - that said, i recognize the possibility that that last question was posted to yank my chain a little, in which case i can take the joke as well as anyone...
