QUOTE(ConeDodger @ Jan 8 2008, 01:04 AM)
If I recall correctly, L-Jet uses a air flow meter that is really measuring he position of the flapper door in the AFM itself on a potentiometer. It also uses a throttle position switch much like D-Jet. It measures cylinder head temperature. The injectors fire for a percentage of time and that percentage goes up as the need for fuel as measured by the flapper door, the throttle, and the head temp dictates. The L-Jet on 280Z cars has dropping resisters to bring the voltage down to what is needed to fire the injectors. I am not sure if the VW Porsche L-Jet does.
I don't believe one is superior to the other. With the possible exception of the fact that we don't seem to be able to get berylium to rebuild the MPS on the D-Jet. The L-Jet seems to be easier to get rebuilt...
I hate them both. More patient men will disagree.
The throttle position switch on an L-Jet system is not like the D-Jet. It only has 2 switches, one for idle, and one for WOT. On the 912E they eliminated the idle switch. And the L_jet on the 914 uses a set of dropping resistors.
QUOTE(r_towle @ Jan 8 2008, 08:49 PM)
Going back to why L-jet is open and JH jet is a closed loop.
I think its an emmission issue given the timing.
EFI was forced evolution by the EPA...take a look at carbs from the 70's through the 80's
By the end, the carbs had 20 vacuum lines running off of them and were impossible to diagnose, it was a rats nest of sensors etc.
L jet was simple, and it cleaned up the mess of lines, and lowered the emissions.
the evolution to LHjet, with a lambda sensor was a natural evolution to keep up with the progressing laws of the time.
I think that LH jet was used by the japanese cars for years.
Rich
The LH-Jetronic system was used on most Volvos. It is almost idenitcal to the L-Jet system on a 914, with the exception of a Hot wire Mass air flow sensor, and an O2 sensor for feedback.
QUOTE(davesprinkle @ Jan 9 2008, 10:32 PM)
QUOTE(type11969 @ Jan 9 2008, 09:26 AM)
Ljet at least doesn't have the trigger wheel in the distributor like Djet, I was happy to find this out when I started poking around my new bus because it allows you to run a mallory (at least more easily than djet). That doesn't mean that the injection event isn't still timed off the distributor in some way, but how . . . dunno.
Definitely really digging fi though over the dells in my Beetle. One thing that bugs me about this old fi though is it doesn't have the limp home abilities that carbs do.
Yes, the L-jet ECU receives engine speed information from the ignition signal. That's why the injection harness has a terminal that connects to the switched side of the coil. Amaze your friends with this bit of ancient injection trivia -- because every coil pulse looks the same as any other coil pulse, the L-jet ECU is UNABLE to track engine position. It only knows the SPEED of the engine. Since the ECU doesn't do, indeed CAN'T do, injection phasing, your mallory will work just fine.
Modern ECUs rely on a crankshaft signal that is modulated in some way (for example, with extra or missing teeth) so that the ECU can deduce crankshaft position as well as speed.
The L-Jet system uses a circuit in the ECU that is identical to a tachometer. It listens to the pulse on the negative side of the coil and fires ALL 4 injectors on EVERY OTHER pulse. So half the time the fuel is being fired at the back of the closed valve. But the injector dwell is half of what it would be on a sequentially injected car.
L-jet is the second generation of EFI. D-Jet came first. L-Jet was the evolutionary base for LH-Jet, digifant, and Motronic. D-Jet was the evolutionary base for some of the GM Delco systems that use a MAP sensor to determine engine load.
