SOLD!!!
Package deal: $1950 obo (That's less than $5 per item as a package deal)
Contact 865-463-2575 or 914rrr@comcast.net.
Pair of NIB Euro taillight lenses
Rear floor pan – new – aftermarket w/seat track replacements
Longitudinal repair panel – new
Longitudinal reinforcement – new
Dash units – lower – qty 2 (1 w/vents & 1 w/o vents)
1 front bumper rubber top pad
Complete steering housing w/ignition lock, key, wiper switch and turn signal switch
Box full of 914 wiring and fuse panel(s)
Several washer bottles w/hoses
Several exterior door handles
Interior door handles w/ covers and rods
Pair of 70-74 fog lights
Partial 75-76 2.0 injection system
2 mostly complete 73-74 2.0 FI systems
OEM Leather steering wheel – needs recovering
Tail shifter tranny
Rebuilt side shifter tranny
Headlight assemblies w/covers, eyebrows, & surrounds
Several heater blowers w/single and dual outlets
73-74 OEM 2.0 muffler
3 early interior rearview mirrors
Dash w/dash cover installed
3 73-76 engine support bars
2 engine lids with grills
75-76 Bursch muffler
1.7 aftermarket muffler w/hanger bracket
75-76 OEM black basketweave dash face
Several interior windshield pillar trim
OEM Engine sound deadening pad – nice from low mileage barn find
Vacuum and fuel line hoses – New braided fabric style (several feet)
Several front and rear brake calipers
NEW Front rotors w/bearing, races, and seals installed (never installed)
New vent window seal
Several new and used keys
Several tumblers and tumbler parts
Rear deck lock
Several pairs of drain funnels w/hoses & gaskets
75-76 bumper snubbers – qty 2
Several front turn signal housing, lenses, & seals (lenses are US, Euro, & Italian)
¼” 5 lug spacers (pair)
Several side marker housings w/lenses
4 exterior mirrors
Complete gauge cluster w/housing – silver button – 150 mph
Several pair of headlight motors and mechanisms
New 914 / Early 911 pressure plate
75-76 Bra Colgan
Pedal board
Misc OEM & aftermarket carpet pieces (black to salt/pepper)
Several center console components (Brackets, gauges, frames, center pads, leather shift boots etc)
2 pairs of armrests / door pockets
2 rear decklids (1 rust free w/small dent, 1 is in fair to good condition)
Lower front suspension cover plate
Pair of aluminum valve covers
Several OEM valve covers
2 4cyl fan housings (1 w/flaps)
1 fresh air blower w/housing
2.0 complete gasket set
Several new / used cables
Several chrome OEM window cranks
Several black OEM window cranks
Pair of 75-76 black OEM window cranks
Several (20+) black nice aftermarket window cranks
12+ valve cover gaskets
Several rear trunk top holders – rubber & plastic
Several switches w/knobs
3 new oil filters
2 thermostats w/brackets (1 with cable and pulley)
Pair of Koni red shocks and springs
Several roll bar trim pieces
1 205/50/15 Falcon Azeni tire – new
Door thresholds w/trim
Distributor w/FI points – OEM – New/rebuilt
71-73 rear chrome bumper – surface rust, no rust through – good core
75-76 HE’s w/ header tubes
73-76 Rain tray – excellent cond
Early heater blower w/bracket
OEM & aftermarket window / targa bar rubber seals
2 pairs door stops
Combo gauge (gas and oil temp)
Fresh air vents & flappers
Seat belts
Motor mounts – new and used – some w/brackets
Several wiper motor assemblies
Used windshield to top seal / not very old – usable cond
Horns
70-74 gas tank w/mounts, filler neck, & rubbers
5 used taillights w/housings – US spec
1 used taillight w/o housing – US spec
Pair of new OEM euro taillight lenses
2+ sets of OEM alloy lug bolts
1+ sets of the OEM steel lug nuts
Used and rebuilt starters
Used and rebuilt alternators
5 914 jacks
3 OEM horn pads
1 targa top w/latches
3rd brake light assembly
OEM hoses (longs to dash w/seals)
Several ashtrays
Early shifter
Several heater flappers
Several heater tubes & J tubes
Complete 2.0 flywheel / clutch assembly – from low mileage engine
Lots of lower engine tin (cylinder tin and air deflector tin)
Alternator boots
6 speaker grills - factory OEM
Several rear alignment shims
Tan cotton seat covers w/black piping - like new
Repro factory repair manuals
2.0 engine cooling fan (no broken fins)
Several relay boards
1 NOS relay board cover
Several used relay board covers
Front trunk cable with pull handle
.....there is more in our garage that we have not listed! Someone will get a great deal!
