Our 1972 914 1.7L has almost 2 deg. of negative camber on both rear wheels. We want to reduce the camber to less than 1 degree. There appears to be one thick shim (or spacer) on each side (estimate about 1/4" thick). I do not know if these are original or not. I have not taken it loose yet.
Question is, what is supposed to be there, shim(s) or shim(s) plus a fixed thickness spacer that all cars came with? To get the desired factory -1/2 deg. negative camber were the cars delivered with a fixed spacer and then a series of shim(s) added to get the desired camber, or was the space totally filled with shim(s) of various thicknesses to get the camber? Could a car have been delivered with no shims, or was there always at least one (thick?) shim/spacer? In my case it it possible that shims have been removed by a PO and what is left is the spacer, or what is there is a shim and I have another problem? I understand it is possible our springs are weak which could cause the excessive camber.
What have other owners found when they went to adjust their camber?
Thanks,
jjs3rd914
