McMark
Jan 11 2008, 12:45 PM
Porsche used various sizes of clear plastic hole plugs in the cars, I'd like to compile a list of:
a.) How many plugs?
b.) What are their sizes?
c.) Where are they located?
I know there are two on the top of the transmission cross members. There are two on the bottom of the cross member on non-swaybar cars.
I know they were used more places.
boxstr
Jan 11 2008, 01:11 PM
Actually there are three in the holes in the rear trunk. There is a plastic plug for that really small hole between the two larger ones.
Craig C. Laughlin
Oregon Region
JeffBowlsby
Jan 11 2008, 01:48 PM
Both my 74 cars have rear sway bars and both large plastic plugs on both the top and bottom
McMark
Jan 11 2008, 01:59 PM
Thanks guys!
I remember two more, the back side of the front suspension mount in the front trunk.
IronHillRestorations
Jan 11 2008, 09:05 PM
The small hole in the rear trunk is for the spare tire bolt.
9146FAN
Jan 12 2008, 10:11 AM
My '70 has three plastic plugs on each side where the bolts that hold the rear trailing arms bolt to the suspension consul. My guess is they're 8-10mm. I don't think they were used on later cars.
There's also 3 small plastic plugs on the underside of the roll-bar. They cover the ski rack mounting holes.
watsonrx13
Jan 12 2008, 04:36 PM
There are (3) plastic plugs on each side of the car that cover the rear suspension bolts that hold the shim plate for the rear axles...
-- Rob
For the interior, there are:
(5) on the bottom of the roll bar pad
(7) on the front of the roll bar pad
(1) on either end of the knee pad - (2) total
(2) on the driver's arm rest
-- Rob
