QUOTE(JPB @ Jan 12 2008, 11:54 AM)
I want to do the Wevo thing and was wondering if I could use the 911 hubs and axels on my 914 rear? Will the hubs press right in and what about the brakes, can i use the stock setup? if you wanna know, have a donor available so am considering it.
The 911 hubs and axels are no problem if you are running a 915 trans. You will need the inner and outer hub spacers made by Patrick Motorsports so your rotors are centered in the stock 914 rear calipers. You will of course also need 914-6 rear (5 lug) rotors. Easy swap and well worth it (cheap) Stock 914 rear wheel bearings are utilized.
Call Jim Patrick at PMS!
