The nights here can get chilly... not as cold as Iowa or Kansas, but still can be cold. So, I bought an old bullet heater for 50 dollars. It's an older unit (probably built before 1980), but overall seems in good shape. It heats well, but has a bit of a stutter.
I pulled the ignitor plug to check and see if it was fouled. The threads on the plug and the plug hole were stripped - the plug with gnarly threads was just kind of stuffed in there. The company was bought out ~1975, but someone kept producing the thing and most of the parts are still available.
I figure I can helicoil it, but then I discovered something else... it appears that the plug is locked in place with some kind of set-screw.
So... any ideas on how to repair this?
