Hey Everyone!
It was about 2 years ago that I stopped posting around here. I had a 72 that I spent a good amount of time on. I was able to do the things on it from the information and resources available here. Unfortunately, I was rear-ended on the freeway by an uninsured illegal immigrant. Click to view attachment
After that happened, i got rid of just about everything and got a new car. Well I am sick of car payments, and i realized how much i missed having a 914. Found a pretty nice 73, injected 1.7 on craigslist and just picked it up 2 days ago. Pics to come tonight.
First thing is first though, I am having trouble starting it. To add, it is a somewhat intermittent issue. When you turn the key to on, the fuel pump goes on. What was happening was when i turned the key after the fuel pump came on, and got nothing at all, no attempt to crank. The advise i got was that is was most likely a bad ground to the tranny. Last night, i got the strap off, cleaned the terminals and nothing. Then i did the same to both leads of the battery. Still same problem.
Out of mild frustration, i put some force into turning the key, and found that if i push kind of down and in while turning the key i can get it to turn roughly 3 out of 5 tries. Is it a bad ignition switch or something else? Some other info is that in my attempts to turn it on, one time i turned the key and the horn went off.
Where to start?
GLAD TO BE BACK!!
--Ben
