Hello All
Looking for feedback on a 2.7 6 I am considering purchasing.
I have been on the slow hunt for a larger motor for my 914-6. I am currently running the original 2.0/6 engine. I appreciate all the advantages of modern fuel injection but for me the retro feel/sound is important so Webers are what I want to run. I also need to stay within budget by re-using as many components as possible. I will be using my stock heat exchangers, tin, webers. The 2.7 will let me use my flywheel I believe. Looking for 180HP, I dont mind peaky motors.
My local independant Porsche repair guy has a customers 77 2.7 motor on a stand. The customer upgraded to a 3.0 after dealing with too many issues. The customer wants 3k for it.
History
Was rebuilt by another shop 10K miles ago. receipts are available (he has to look for them)
New P/C's dont know what type/brand
New Carrera tensioners
New Alternator
Line bored and case stud inserts used
Head redone
The Bad
Leaks oil (a lot). Nice shiny coat underneath. Shop owner thinks it need to be disassembled and reasealed at the minimum
Owner had a bad alt, light was on, ignored light then threw a fan belt, was driven hot for a while. It was driven into the shop still running well. Smokes. Not sure if its burning oil inside or outside
So my impression is that the motor needs to be checked out entirely. (disassembly) I have experience with type 4 rebuilds but my 1st 6 rebuild. I have been reading the Dempsey book nightly. I am aware of the potential costs. The shop the motor is will help me with tools/checking tolerances.
Is 3K fair for this motor with its baggage or do I stroll down to my local Porsche dismantler and spend 5K plus for a 3.0 with unknown history and buy a custom flywheel/clutch setup for my 901?
thanks for thoughful responses.
John Daron
