BigD9146gt
Jan 21 2008, 01:31 AM
Hello all,
For those of you who don't know me, I make the DWDesignWerks aluminum 914-6 oil tanks. I'm in search of an original 914-6 "oil return" hardline to copy, I'll pay for shipping both ways and send it back to you the next day... as well as send you a reproduction (mandrel bent, metric spec fittings) once they are done. I usually work about 14hrs a day, and I rarely get a chance to check these postings... so if you could please respond via email it would be much appreciated. Don@DWDesignWerks.com.
Cheers,
Don Welch
DWDeisgnWerks
rudedude
Jan 21 2008, 09:27 AM
Don,
I tried your email and was rejected.
I think I have one on the shelf if you need.
Let me know.
Jule
Jeffs9146
Jan 21 2008, 09:36 AM
Me Too!
sww914
Jan 21 2008, 12:18 PM
I'll call him and tell him to check this thread.
BigD9146gt
Jan 21 2008, 01:01 PM
QUOTE(sww914 @ Jan 21 2008, 10:18 AM)
Thanks Steve, just got it.
Jeff, I received your email but not Jules... so i'm not sure whats going on. Jules, you responded first, so if its ready to ship, I would rather keep Jeff from going through the hassle of removing his.
Again, thank you both for the timely response.
Jeffs9146
Jan 21 2008, 02:27 PM
No problem Don! I am pulling everything out anyway for a complete restoration so let me know if you still need it. I can pull it out tonight and since I am in California UPS Ground would have it to you by Wednesday!
jim912928
Jan 21 2008, 06:12 PM
Don, I bought one of your tanks (great item!) and am still collecting parts to start my conversion this spring. I WILL BUY ONE OF YOUR OIL LINE KITS...put me first in line if it will be available this spring!
SLITS
Jan 21 2008, 06:26 PM
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount.
sww914
Jan 21 2008, 08:04 PM
I think Don has an RJ mount on his car, he might have a trick up his sleeve?
ClayPerrine
Jan 22 2008, 08:18 AM
QUOTE(SLITS @ Jan 21 2008, 06:26 PM)
That is completely true. I put a factory 914/6 hardline on my car, and it would not clear the Rich Johnson mount. I called Rich, and he looked at it. No Bueno. To use a factory hard line with an RJ mount would require hacking up the mount to the point of causing structural problems.
There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly.
dfwteenerpr
Jan 22 2008, 12:11 PM
QUOTE(ClayPerrine @ Jan 22 2008, 06:18 AM)
I need one of those... any body have one?
ClayPerrine
Jan 22 2008, 12:18 PM
QUOTE(dfwteenerpr @ Jan 22 2008, 12:11 PM)
Call Zims. They should have them in stock. You can go pick it up today.
Jeffs9146
Jan 22 2008, 06:09 PM
Don,
It will be at your place on Thursday! Let me know if you want the tracking #.
BigD9146gt
Jan 22 2008, 10:11 PM
QUOTE(dfwteenerpr @ Jan 22 2008, 10:11 AM)
GPR makes the flex line substitute for the 914-6. (800)321-5432, talk to Derek.
sixnotfour
Jan 22 2008, 10:42 PM
70-71 911
Jeffs9146
Jan 30 2008, 07:03 PM
OK, I got it back today Don! Thanks for the quick turn around! I can't wait to see what you end up with!
jim912928
Jan 30 2008, 07:12 PM
Don...will this work with a six conversion with the RJ mount?
Jeffs9146
Jan 30 2008, 07:23 PM
As stated above, the line will not work with the RJ mount!
