QUOTE(jrinvent @ Jan 22 2008, 10:21 AM)
The picture you send looks similar to this one you sent except tht this one has the heater fan motor across the top.
they all look similar ...
if your air filter (the big black box on top) looks *EXACTLY* like the one in the picture above, it's a 2.0L ...
if it looks somewhat similar, but different, it's a 1.7L ...
get a flashlight and look around under the battery tray area, it's also called "the hell hole".
if there's rust, you'll find it there. you have to dig a little, there should also be a bracket with the FI brain attached to the battery tray, so it's hard to get a good look underneath.
there's a cavity there which is in fact the top of the pass. side longitudenal. poke generously with a screwdriver.
also, slide the pass. seat all the way forward, lift up the carpet behind it and inspect the floorboard for rust.
there's black tar glued to the floor, look for cracks in it. press down on it firmly and listen for a "crunch" noise (rust under the tar) ...
oh, and
Andy
