914ghost
Jan 7 2004, 08:09 PM
Hi guys,
I have a feeling about the answer to this, but I like opinions/experience...
POR 15 is great, but my battery tray while pretty darn solid has some corrosion (that isnt compromising structural integrity) w/ surface rust.
Can I POR15 right over the corrosion, or should I neutralize the battery acid corrosion first?
And if so, what have people had best luck with that (1) I can apply easily in the garage (without having to drive the car through 3 feet of snow somewhere) and (2) without removing the engine AND (3) wont keep the POR 15 from sticking?
DuckRyder
Jan 7 2004, 08:30 PM
*I* would hit it with a wire brush, marine clean, metal ready, Por15, then top coat it with a high quality top coat.
A "starter" kist should have what you need in it, less the high quality top coat.
I don't see how neutralizing it with baking soda prior to all this could hurt, the marine clean should remove any remaineing soda.
DuckRyder
Jan 7 2004, 08:35 PM
OH yeah, IT WORKS!!!!!!!
Bruce Allert
Jan 8 2004, 12:20 AM
with the neutralization of the acid. I did an experiment where I wirebrushed all rust off some plumbing parts then coated with POR 15. The experiment: on half of the parts I lightly took off the flaking rust but not down to clean metal then Por 15'd them. It's been 6 months, no rust has returned on any of the parts and they get soaked with detergent and high salinity water daily. It's good shit Man
..........b
914ghost
Jan 8 2004, 12:30 AM
I figured as much, the car is in storage now, I'll get to it as soon as I collect all the parts for the interior, sandblast bumpers/valences for paint.. etc etc..
Now that my tiny garage is empty I can work on my OTHER project:
ChrisReale
Jan 8 2004, 12:43 AM
QUOTE(914ghost @ Jan 7 2004, 10:30 PM)
How dare you blasphem
914werke
Jan 8 2004, 10:20 AM
Im supprised more teener owners dont RIDE!
Air_Cooled_Nut
Jan 8 2004, 11:56 AM
QUOTE(rdauenhauer @ Jan 8 2004, 08:20 AM)
When the weather is nice, I do!
As to POR15, get the starter kit. Has enough to do the whole pan of a VW Type 3
I would definitely recommend cleaning the area first and then follow the instructions. Do the job right the first time. If you want a half-assed job then send it to a
mechanic.
DuckRyder
Jan 8 2004, 12:04 PM
Mee too.
And the oil was here when I moved in, it looks a lot better now after lots of cleaning.
914ghost
Jan 8 2004, 12:08 PM
psssh...you probably never even use 6th gear on that thing (legally)!
I know I know! I've seen your Avatar!
Go ahead, rub it in some more!
jfort
Jan 9 2004, 02:02 PM
Check this out: Eastwood's product versus POR 15. Any thoughts or experience?
http://www.eastwood.com/RustvsPOR.asp
Evill Ed
Jan 10 2004, 07:42 AM
I rides too!!
Ed
BTW- POR 15 WORKS !!
TheCabinetmaker
Jan 10 2004, 07:47 AM
wow, its a yamachopper
