QUOTE(yenningComity @ Jan 26 2008, 09:33 PM)
If the motor runs strong once you start it up. I say put the money into your suspension. Reliability, cheap, and more power never all go together.
QUOTE(bandjoey @ Jan 26 2008, 09:45 PM)
Thanks Degreeoff, I'm adding you to my list of people to talk to. I figure on putting about another $1k into the body and suspension. Your blog on the rebuild I'll be looking over . Have you seen anything like that for a T4?
Some people have said I should be looking for a used 2.0 and sell the 1.8? Details...Details...Details...I'm on thought overload for Saturday night.
Ok I agree with the 1st quote, as for the second (yours) what do you mean for the type IV? you mean pistons/cylinders? carbs? cam? rings?
Here is a link for pistons @ EBS
http://www.ebsracing.com/RenderScriptTempl...entid=ebsracingHere is a link for CURRENT porsche carbs (40mm would be best)
http://search.ebay.com/search/search.dll?f...&category0=And a cam you will need to make power withe the carbs....my 2000 mile scat with solid lifters would work fine or you could go a bit more radical up to you?
Now it is a long debate over carbs and FI...do a search and you will see. I personally didnt have the patience to dick with the FI and prefered being able to understand my car.....(in hindsight the FI isnt that tough) but again I had carbs on mine and even forgot to tighten one carb down one time and ran it until I was a ways away from home with one carb haning off almost (loose as hell!!) but went back and saw the issue tightened it up with a pair of pliers and got home....(thats pretty much monkey simple and stupid reliable if you ask me) now milage sucked but it was an occasional driver.
If you go radical with the cam (say a step above the C-25 scat) then you will NEED carbs as the FI will not keep up (I believe)
