Hello,
Im in the process of installing the front oil cooler in my car. The lines run back thru the drivers foot well then down under the left rocker cover.
My question is, once you get past the jack post and you want to have the lines turn towards the engine bay, what route do you take with them?
Do you just come around the frame or do you cut another hole around the jack post to gain access to the engine bay?
Using the heater duct isnt an option.
I am using a standard 914-6 oil tank
A pix would help out.
Cheers
