QUOTE(KaptKaos @ Jan 27 2008, 07:28 PM)
I bought a new ignition switch from Pelican and need to install it. The old one was sticking and keeping the starter going even though I had taken the key out!
I had a similar problem after coverting to the SDS EFI. The motor would keep running after the key was off. No starter problems, but the motor itself would keep running- you could pull the key right out of the switch and it just kept going! I tried a new switch, but that did not solve the problem. Turned out I was getting some wierd charging system feedback loop thru the dash light- I added a diode in line to the gauge light and that fixed it. Took a bit of searching, but found the answer here in the forums. If you went with some a/m ignition system on the motor, and you try the switch replacement but that doesn't do the trick, search a little to learn more on this other problem w/similar signs.
