After using stock valve springs with my high(er) lift cam, and crushing a spring.... I rebuilt her with a little less cam and a little less on the intake. Used the right springs. Also upgraded the oil control seals on the valves. ;-) People mentioned a little smoking issue... they were right. It was the valve seals.
The results are a smoother idle, stronger standing stop-starts at lower RPM's, waaaaay more mid range and more torque at higher RPM's. And throttle response that is fantastic.
***Lessons learned***:
~ VERIFY the advance curve of a used EBay distributor before putting it in a new engine.
Mine was already advancing at 500 RPM's and the vacuum advance was locked down and didn't advance at all. =-P ( It never did run "right" before. Now it does)
~ Make sure to follow manufacturers specs on valve springs/keepers/seals.
~ High RPM intakes do not make for a streetable engine, but it looks cool.
~ High RPM cams do not make for a streetable engine, but it sounds cool.
~ Component matching makes a huge difference in overall throttle response and performance.
You all knew this already but I've never personally experienced such a night/day change in the same engine as this last rebuild. Amazing.
Thank you all for your support!
I just spent 2.5 hours running up and down the east bay area highways and hills in freezing, crisp weather. A perfect non-AAA evening.
Roger
