QUOTE(davep @ Jan 29 2008, 06:33 PM)
Just consider the heartache that Dave Hunt went through rebuilding his engine so many times due to Megasquirt problems.
QUOTE(749142 @ Jan 29 2008, 06:52 PM)
QUOTE(toon1 @ Jan 29 2008, 06:09 PM)
MS is cheaper than SDS.
Jake swears by SDS.
Both are good and both work.
MS can be DIY or you can buy an assembled unit. You will need a laptop for tuning and I stronly suggest a 02 sensor.
U wouldnt happen to know how much an assembled unit costs would you toon1?
steven
QUOTE(749142 @ Jan 29 2008, 06:53 PM)
was it problems with his ms or was it him causing the problems.
Dave's motor is completely different.
MS will fuel 700+hp engines with no prob.
BUT who am I to argue.
You can go to DIY auto tune and checkout their assembled units. I think the MS II, which will also control timing is in the $400 range. You can find them used on the MS site or on ebay
You can go with a MSI unit, they are cheaper, and load the MS&Se code. this will also give you timing control but at a lesser resolution(which you willnot need).
Here is my BIASSED .02(since I own an MS)
MS is just fine and don't be afraid of it. it works and works good. SDS is good, Jake does prefere it.
MS is about 1/3 the cost.
I have looked at the specs. on both units and, for the life of me cannot see the difference.
It has been said that MS had too many bells an whistles
It does have alot avail. but for a TIV it's basic.
SDS has a 16x16 fuel table, there is 16x16 avail. for MS also but MS primarily uses a 12x12.
You can use the same sensors for both ,ALTHOUGH, MS has the ability to use the air cooled sensors with easy therm.
SDS had limited info about their unit on it's site BUT from what I've heard has great cust. service.
MS has a lot of info on their unit and has a website forum to support it
It comes down to this........... do the research on both and decide what are YOU comfy with?
