These were advertised as rear 996 or Boxster S calipers but I'm not sure they actually are because they don't fit over a 996 rotor. Can anybody tell me what calipers these are?
Before I bought them I figured they were 996 calipers since i think the boxster S ones are painted red. The part number on the caliper is 996.352.421 and 422.
I tried to slide them over a new 996 rotor and they don't fit. The spacing between the pad retainer pins (or whatever they are called) is too small - see the white mark on the first pic attached below. The boxster S has a 24mm thick rotor just like the 996 so i assume these do not come from a boxster S either. I don't have a boxster S disc so this is only an assumption based on rotor nominal specs (24mm thickness).
The calipers can easily fit over 20mm thick rotors but I thought that the standard boxster calipers had a 986 part number.
If anybody can tell me what these calipers are I would very much appreciate it.
Thanks
John
