Ray Warren
Jan 10 2004, 07:49 PM
i can't get the light for my heater fan to work.
(the one on the floor)
it has a good ground and i have tried a new bulb.
any thoughts?
TheCabinetmaker
Jan 10 2004, 07:52 PM
did you turn on the lights? mine hasn't worked for 10 years and i've since taken it out, but I seem to recall that the light comes one with the head lights. not with the switch. Someone correct me if I'm wrong.
Ray Warren
Jan 10 2004, 07:55 PM
no i did not try that.
makes sense though
rhodyguy
Jan 10 2004, 08:26 PM
i do know if it shorts it will kill the instument lights and the fuse.
kevin
Andyrew
Jan 10 2004, 08:53 PM
Hold one one second, what defroster light? What fuse? Instrument lights?
I know that I have one fuse that is prone to popping (when the headlights come on, take it out, and the headlights still work) What wire are we talking about here? What light, where?
Aaron Cox
Jan 10 2004, 11:09 PM
on the center tunnel or center console. 1" x 1" black thing
redshift
Jan 10 2004, 11:38 PM
I broke the bulb with a screwdriver, and taped the wire up, no porpoise.
Flipper
Andyrew
Jan 10 2004, 11:52 PM
Ohhhh that thing
nm
Jan 11 2004, 02:57 AM
yepp, comes on with the lights, not the heater blower ...
and yes, they like to shorten out and take out the entire dash lights with them. ground and + are only about 1mm apart.
Andy
rhodyguy
Jan 11 2004, 09:41 AM
my thought is it's sole purpose is to direct you to the heat handle while driving at night. "now where is that heater handle?". if the wire is chaffed away from the light housing the same shorting will occur. my wife wanted to know why the dash lights no longer worked after i did a shifter adjustment.
kevin
