The driver's side, right below the pushrod tubes and underneath the engine tin says: S12 004.101.102A VW 4
The passenger's side says: S12 004.101.101A VW 7
What do I have here. I've been told its a bus engine. Are both halves original to each other?
Many Thanks, Konrad 72/4
type47
Feb 25 2008, 08:57 PM
if you want to know what engine it is, look at the engine serial number. EA is 1.7, EC is 1.8, GA and GC are 2.0, CV is a vanagon engine. there are others.
Feb 25 2008, 10:28 PM
QUOTE(type47 @ Feb 25 2008, 06:57 PM)
engine number should be on top of the engine and related to those on the list below ...
those are the part #'s for the engine case halves most VW & Porsche part #'s have a similar format when the #'s are cast into the case in raised letters then they are not serial #'s
