QUOTE(pete914 @ Feb 27 2008, 11:24 AM)
Purple,
what did you change when you switched from the single carb to the dual? What additional parts do I need to buy? what dizzy are you running?
QUOTE(purple @ Feb 27 2008, 09:50 AM)
Yeah, I got around 14MPG with my weber progresssive, so fuel milage is ass with them. Mine was WELL tuned from the P.O. when I got it, apparently that was the only thing he did right on the car, because everything else engine-related was pure shit. The problem with dual carbs is syncing. other than that, i've got dual weber 40's on mine and it starts and idles fine after two taps on the gas pedal (who needs choke? NOT ME!) It just needs tuning REALLY bad.
Oh, dual carbs sound f'n incredible
It's not as parts-intensive as you think!
I ordered the dual weber 40 IDF kit from Jake RAby's store. They come with all the manifolds, bracketry, hoses, hose-clampery, t-fittings all that. you might want to get the throttle cable holder from triad west. if you go to their website they have a 'linkage kit' that i hear you can order the throttle cable holder seperately if you ask nicely. I went to o-reilly and got a different T fitting because the one they supplied is much too small to actually use with the fuel tubing i have in the car.
I have a CB rotary fuel pump underneath the fuel tank that solved a lot of issues just by itself. I have a mallory unilite recurved by Jake raby and a mallory promaster e-coil with a ballast resistor. I set it all up and it worked the first time! make sure you adjust your valves correctly or tuning will be a major bitch. It's really straight forward and easy. the hard work is already done if you have a car that drives and runs on a single carb. tossing in duals is a piece of cake at that point.
