Here is the tower in the tube chassis setup. I had made a simple adapter plate out of 3/8" aluminum to mount the tower to the stock location in the stock tub... anyway, you also see a simple aluminum bracket I bolted to the tower and that is where the push/pull cables mount (2nd pic)
Here is the simple "arm" I came up with to adjust the fore/aft motion as well as reverse it for mid-engine use. The cable bolts to a round hole, the heim setup that mounts to the trans interface is slotted and I can change the throw length to where I like it by changing position in the slot. I like it nice and tight now, so pretty much maxed out to the right... you also catch a glimpse of how I come in at 90deg for the left/right motion of the H-pattern. I will add another post of a better pic of that.
