Hi,
I recently started autocrossing my 914. I enjoy it a lot! The car is not really set
up for autcrossing, no sway bars, standard alignment, etc, but it is still fun to see
what I can do.
The tires I am running are Kuhmo street tires. I know they are not optimal,
but I am not ready to upgrade.
The issue is trying to optimize tire pressure. I know the 914 is a very light
car and therefore may not need a lot of pressure. I ran them originally at 35 psi.
That seemed okay. I ran them up to 40 psi, and while fun to slide around, it was
way too much! I am now running 32 psi, and I don't know if I should go lower or
not.
How does the pressure vs cornering curve go? I would think the cornering force
would increase with tire pressure up to a point, and then tail off. Any ideas what
the range should be? 25-35 psi? Higher? Lower?
I'm just looking for general guidelines. Tires are 195/50's on 5.5 inch fronts and
6 inch rears at the moment.
Thanks,
Jeff
PS: Autocross video
