I've got a '69 911T and the oil light is glowing. The pressure gauge is showing 20-30 at idle and goes up to the top when the engine is revved up. It sounds and drives fine so I guess that there is a fault with the sendor or the wiring. What does everyone think? My 911 experience is still limited
So, question 1:
Is the gauge reading normal?
Question 2:
If it is, where should I be looking for the pressure sendor? I've found the temperature one at the rear right of the engine block next to the bottom of the fan, and I found a 2 contact sendor in the top of the block in front of the fan housing - what does that one do? Removing the wires doesn't seem to make any difference.
