computers4kids
Feb 28 2008, 07:48 PM
I have this rebuilt motor that is offered at a reasonable price to me. It has oversized pistorns and 1.8 heads.
As I understand it, a 1.7 and 1.8 have essentially the same stroke, just different bore.
How do 1.8 heads effect a 1.7 motor?
Thanks
Brando
Feb 29 2008, 03:23 AM
I think the question should be "how do 2.0 heads effect a 1.7/1.8 motor?"
To answer your original question... they won't too terribly much. They might flow a little better.
valve sizes for 1.7:
In: 39.3MM
Ex: 33MM
valve sizes for 1.8:
In: 41MM
Ex: 34MM.
alpha434
Feb 29 2008, 04:26 AM
Lol.
Flow= HP
The problem with 1.8s isn't the heads. Well. Spark plug location plays a part. It's mostly the funky fuel injection setup. Is the rebuilt engine going to come with FI? What type?
computers4kids
Mar 1 2008, 09:46 PM
QUOTE(alpha434 @ Feb 29 2008, 02:26 AM)
Lol.
Flow= HP
The motor is setup with djet injection for a 1.7 (not L-jet) and is suppose to run very good.
He can't find the MPS, and I forgot to see what color the injectors where...should be yellow. The MPS and injection came from a 73 1.7. The guy spent a lot of money having the motor professionally rebuilt years ago.
Anyway...should I get excited
toon1
Mar 2 2008, 12:54 AM
If I'm not mistaken, the registers is the 1.8 heads are too big for the 1.7's
1.7=90mm bore
1.8=93mm bore
alpha434
Mar 2 2008, 08:29 AM
It's close enough.
Hey. A deal is a deal. It might run pretty strong. It might just be good for a lot of spare parts...
jr91472
Mar 2 2008, 12:40 PM
Just a thought...
Don't assume they are 1.8 heads. I have the same setup, but the 1.7 heads were simply opened up to accept the 1.8 cylinders by the PO.
I have heard this is (or was) as fairly common thing. I have no way of telling you how to tell the difference between and 1.8 and a 1.7 head without taking them off and measuring the valves.
sean_v8_914
Mar 2 2008, 12:48 PM
in post 1 he states it has a big bore. remove the valve cover and read teh casting number does it end in 371 S
Brando
Mar 2 2008, 09:46 PM
go with a pair of happy 2.0 heads and race your shorts off.
HAM Inc
Mar 3 2008, 08:35 AM
The 1.8 heads do flow a little better than the 1.7 heads. If the last four digits of the casting # in the rocker chamber are 371s then they are 1.8's. The increase in flow is enough to make a difference if the cam is updated. With the stock cam you won't see much difference.
computers4kids
Mar 3 2008, 08:52 AM
QUOTE(HAM Inc @ Mar 3 2008, 06:35 AM)
Yes, the heads are definitely 1.8, in fact the owner has reciepts for all the work...the heads are brand new (not rebuilt).
Thanks all for your input...
HAM Inc
Mar 3 2008, 10:32 AM
If your heads are new AMC heads that are stock then you will see no difference as compared to a 1.7. All of the T4 AMC heads are cast with identical intake ports, regardless of engine size.
