QUOTE(Cevan @ Mar 1 2008, 05:25 PM)
I'm talking about the flexible fuel line that runs from the fuel pressure regulator to the return line.
Click to view attachmentyes, that's the one in the side view pic about the middle of the engine tin. sorry for the dark pic. you might be able to see it come over the engine case to the immediate left of the blue coil and hanging off the engine sheet metal in the front middle. it's the black image about 3-4" (rather, 10 cm long
) to the right of the intake runners.
PS: my cable from the battery to the starter was mounted on the back side (not engine side) of the back engine sheet metal, the vertical piece with the curved top. the cable went thru the tin on the passenger side thru the hole, went thru 2 cable ties (like the one in your pic), then to the starter post. don't know if that's the factory method or not, i'm not the first owner and might have changed it when i re & re the motor but i would have installed it the same way i took it apart.
