Thanks for looking.
1. Trying to wire my my license plate lights. Right side works fine. Left side seems to have no power. Here's a pic of the setup. I noticed that on the working side. The "two wires into one" connector has been broken up. So, there's a loose wire not connected and then the two wires connecting to the light (+ and -). I'm guessing this is the ground which is no longer connected? The light works though setup like this.
In any case, I don't want to experiment too much as I hear this can fry the wiring harness. Anyone had trouble with this? no paint or rust in the connector; I cleaned them out. should i cut the "two wire into one" up? seems stupid to do that...
2. Here's a pic of my fuse box. Lower right-hand corner shows the hookup for the oil pressure gauge (second from the right). I want to put an oil temperature gauge in the car. Would i hook up that gauge on this fusebox as well? if so, where?
I have the dual pressure/warning light sender now. If i were to wire a temp sensor would i need to run a wire from the sender into the cabin or does the existing wiring harness have a wire for this already? what parts would i need to order? guage and sender?
3. Do the VDO gauges come with lights or do they just assume you don't need to monitor you engine at night?
Thanks guys!
