QUOTE(dw914er @ Mar 4 2008, 08:02 PM)
well, the bucking is intermittin, it doesnt happen al the time, just every once in awhile it will happen
so i guess i will clean it out, and check its progress
as for the leaks, its just the air (right at there the intake is seperated (those sleeves) and then down by the head too
that just results in crappy idle performance (which i have richened the fuel to compensate for the time being) but other than that, there is no other problems
but since i live at san luis obispo for school, and the car is in redlands, ca, it isn't driven, so my spring break i will attempt to fix both (i hear fixing the intake runners take a long time, yay lol)
thanks for the advice
cheers
This is only my humble opinion, But I think you have several problems. None of which need to be expensive. Just a little time consuming.
Let's start with the basics.
If your 914's vacuum lines are more than 10 years old - they all need either replacement or trimming & re-seating (yes, it can work for a temp fix if they aren't split in the centers). 914's NEED to run in a closed environment. Any vacuum leak, and there can be many sources, will screw things up at all RPM ranges. Those intake runners are a prime source for leaks. Replace them - $40 at the most. All the other vac hoses need to be tested for leaks. If they leak, replace them - also fairly inexpensive.
Now - the TPS. Jasons in correct - you can unplug it, run the car & watch the effects. I would guess that your TPS is very old (maybe original), but there are things you can do to help it. Unfortuately, you must remove it to make the work easier - also, not a major deal! IF you decide to remove the assembly, which includes the throttle body, be VERY careful to NOT screw up the supple rubber gasket that fits below the throttle body on the plenum _ I am told that these are no longer available for 1.7's
Once you have the TB and TPS assy removed, pry off the black plastic cover on the TPS body(carefully). You'll see the tracking armature, much like an old record player turntable, and a probable groove cut into the surface. If the groove isn't too deeply cut, you can clean it up for re-use. Clean all the components with contact cleaner. I usually go the extra step to polished the surfaces with Simichrome, BYMMV. The throttle body will be full of gook too, so clean it up & Q-tip the side venturiis.
Once all parts are cleaned - replace & follow the easy adjustment tips -http://www.pelicanparts.com/techarticles/914_cooley/throttle_position_calibrate_17-18.jpg
If the TPS is too far gone, and they are almost unobtainum, look for a low mileage replacement (PM me if you need one).
Go after any vacuum leaks first & fix those. Then look at the TPS. None are a big deal, just remember - these cars are approaching antique status. Keep your head tucked up under the arms of the people on this site. They/we have all (well, almost) the parts to keep these things running smoothly. Just takes a little effort, dude.
Pat
