QUOTE(SGB @ Mar 6 2008, 04:47 PM)
I dunno if I agree. I think there are a few pieces that will ONLY come off after the engine is lowered. At any rate, the ones seen most easily when looking into the compartment (cylinder head cooling and flat pieces on each side) would be an enormous exercise to remove. In fact you would have to disconnect the motor mounts anyway, I think.
As I stated, it is faster with the motor out of the car.
But...it can be done with the motor installed...every piece...
Take off front fan, take off fan assembly, take off intake and plenum...
Now you can get to the head tin, and all the little front pieces.
The rear piece can come out also.
Then you get the fun ones underneath....those suck anyways.
Rich
