stateofidleness
Mar 7 2008, 10:42 PM
ive seen pics of ya'lls engines all shiny and purdy and with REALLY smooth intake runners.
what's the best procedure in painting them and getting a really smooth finish on the pipes?
914Sixer
Mar 8 2008, 08:03 AM
I beadblasted mine before I painted them with engine enamel. Give me a call or bring them over.
830-755-4755
type47
Mar 8 2008, 10:01 AM
powdercoat with a grey paint close to a VW color
DanT
Mar 8 2008, 11:30 AM
bead blasted and repainted using 356 engine grey.
Cevan
Mar 8 2008, 12:53 PM
Bead blasted, then Dupli-color engine primer and paint.
Click to view attachmentClick to view attachment
StratPlayer
Mar 8 2008, 12:56 PM
Stripped old paint, cleaned then powdercoated the color of the car.
stateofidleness
Mar 8 2008, 01:02 PM
whats best/cleanest way to strip old paint?
StratPlayer
Mar 8 2008, 01:03 PM
I used some Jasco, can get it a home depot. Once old paint was stripped gave it a light sanding then painted.
r_towle
Mar 8 2008, 02:40 PM
what is the correct color?
Are the tubes supposed to be a different color than the aluminum flange portion??
And the color, where do you get the proper paint (rattle can if possible)
Rich
Rand
Mar 8 2008, 02:57 PM
Make it clean and smooth, and paint! Choose your method....
Do you want to do it yourself or send it out?
If the latter, send it to a place that will dip it and powder coat it. Powder coating flows real nice. Done deal.
Prep is key.
You can do it yourself with sandpaper and cleaning. Final clean with the thinner that matches your paint. Seriously, simple.... Make it smooth with sandpaper, clean it up well with thinner, let it dry, prime it, paint it. Smoothness will depend on how fine your final sandpaper grit was. And some paints are more forgiving/filling than others.
