Greeting!
About 1 month ago I replace 1st, 2nd, and 3rd gear syncro's. This wasn't my first time pulling the gear stack and all went smoothly.
I did have some difficulty getting the shift forks properly align as I did all of this WITHOUT any type of alignment tool or jig. It took several tries using a spare tranny case, but I eventually got them aligned such that I could shift into each gear.
I now have about 100 miles on the tranny, but occassionally, (every 1 out of 10 shifts??) I have trouble getting into either 2nd or 3rd. When I say trouble, I mean I push up into 2nd (for example) but it just won't go into gear. When this happens, I simply pull straight back (no side to side motion) and push back into second and it goes right in. Same thing happens in 3rd, but like 2nd it only happens occasionally. I can find no pattern to when this happens. It is just as likely to happen on upsifts as down shifts or going across the pattern vs staight up and down.
Do syncro's need break in time? Are my shift forks still out of wack? Other than this, all is well with the tranny. No grinding, no whinning....
Oh yeah, I would characterize my 2/3 gear slider as in VERY GOOD condition.
TIA
