levonfarra
Mar 8 2008, 10:22 PM
I am trying to install the window side seals on the targa top, and they are very hard to slide on, I have sprayed silicon lube and wd40 and it is still very hard. Is there some secret to installing those. Please advise.
Thanks,
Levon
1970 Neun vierzehn
Mar 8 2008, 10:35 PM
Lev,
Years ago I used a coating of liquid hand soap (Ivory I recall) to lubricate the seals where they slid into the targa roof channel. Same technique makes fastening wood screws easier as well, just a little dab makes running long screws into joists and studs a breeze.
Paul
levonfarra
Mar 8 2008, 10:54 PM
QUOTE(1970 Neun vierzehn @ Mar 8 2008, 08:35 PM)
Lev,
Paul
Paul, thanks for the great idea. The second side slid on in 1 minute. I have been struggling with the first one for hours.
Lev
VaccaRabite
Mar 8 2008, 10:59 PM
Liquid soap helps a ton.
I don't know that I would call it a breeze, but very very helpful.
I ended up grabbing the bottom of mine with some plyers and gently pulling from the bottom while pushing from the top. That made it go pretty easy.
Zach
koozy
Mar 8 2008, 11:14 PM
I use graphited lock fluid. Works wonders for me. (your results may vary)
Katmanken
Mar 9 2008, 11:11 AM
Ivory soap makes a wonderful lube...
They even use it in surgical devices as a biocompatable lube.
A little water from a spraybottle can help too...
Ken
