tod914
Mar 10 2008, 12:44 PM
Hey guys, been through a bunch of threads on the AAR. It wasn't clear to me how to test it when it's off the car. There was mention of hooking up a 12v sorce to it so it heats up and closes. How exactly do I do that? Do I hook up a + line off my car battery to the wire off the AAR? Does it need to be grounded when I do that?
Thanks,
Tod
TheCabinetmaker
Mar 10 2008, 12:50 PM
Yes and yes
Rand
Mar 10 2008, 12:54 PM
I gave mine the float test. It sunk.
tod914
Mar 10 2008, 12:59 PM
thanks Curt. lol Rand. So If i drive my car in a lake and it has a good aar it should float? Was always wondering how they did that with beatles.
Rand
Mar 10 2008, 01:50 PM
No, just the AAR.
Mine is without, and I like it that way.
If yours is sticky, maybe squirt some good penetrating lube through it and test again.
p914
Mar 10 2008, 04:51 PM
I have 2 045s available if you decide you want one.
Hammy
Mar 10 2008, 08:55 PM
Where do you put the ground? AAR case?
roadster fan
Mar 10 2008, 11:38 PM
Yep case.
I just took two faulty ones apart and fixed em two weekends ago. If you cant get it working send me a pm and I will post he procedure I used.
Jim
JeffBowlsby
Mar 11 2008, 12:10 AM
Its just a simple heater circuit. Red wire to +12V, case to ground. Shaft rotates on bi-metallic spring to open/close airway with heat.
tod914
Mar 11 2008, 12:16 AM
So when I hook it up to the car battery and ground it, how long should it take before it closes?
Thanks for the replies.
I seen the rebuilt article by Mr Anders. Was rather interesting. The one I have now, is a rebuild from AA. I can see where the lip was cut off then epoxied upon repair. I have the original that went bad do the wire shorting, think I'll try the repair on that being it's toast any way.
JeffBowlsby
Mar 11 2008, 12:37 AM
A few minutes. Engine heat alone is enough to close it even without power.
tod914
Mar 11 2008, 12:50 AM
Jeff Im still trying to locate that 75 engine sticker for you. Haven't forgot about it. If I locate it, I'll be sure to send u a digi photo.
