QUOTE(EyeTrip @ Mar 13 2008, 01:38 PM)
...I was just looking to see if there is a down side to these...
We never felt there was a downside. Only issues I had heard of is some shops had them "back out" and then shit hits the fan, but we always kept the gnurling tool pretty fresh (we would replace it far more often than other shops) and that was the key. If it would even start to slightly "grab" the liner we would get a new one.
just the part where their page is so poorly written (taking into account the differences between imperial english and american english) scares me. It looks like this product was developed for heads without replaceable guides or heads that are irreplaceable and one would be afraid to try to press out the original guides.
Don't let the poor writing scare you, it really is a great product and have been around for YEARS. It is pretty much the standard for replacing slightly worn guides. Now, if you F the guide up a fair amount, you need to install a replacement guide.
That said, you are correct about the intended use - they are more to repair an irreplaceable guide than a removable guide.
HOWEVER, we would K-line VW and Porsche heads often (I forgot to mention this and came back to edit but saw the responses) because the aluminum is so shitty. You would go to hammer the old guides out and the alum would be galled and yank out with the guide. Then you would have a loose hole and you would either gnurl the outside of the replacement guide (essentially rigging the setup) or have to get an oversized guide. We figured if you got a VW/Porsche head and the guides had not moved, we figured that is much better than f'ing with them so we K-lined them.
I can totally believe you had 10yrs of hard use out of K-lined guides. I had K-liners in my 302 Cleveland heads (yes, there is such a thing for you Ford guys doing this
) and I beat the living shit outta that Mustang for about the same amount of time. I pretty much shifted at 6500rpm and it was my daily driver when I was younger.
