John
Mar 12 2008, 09:17 PM
Could someone measure the hole locations for an original 914-6 emblem.
I need a starting point. I know center to center dimensions for the holes.
If I could get a height and a distance for one of the 3 holes, it would be a starting point.
Thanks.
914Sixer
Mar 14 2008, 12:32 PM
Do you have a 914-6 emblem? Take it and press it into a piece of cardboard. You should be able to use those holes for your drilling pattern. Cut the cardboard down to size and use it to center it where you want it.
70Sixter
Mar 15 2008, 10:57 AM
From the right tail lite to the rt edge of the 6 is 1 7/8" and from the lip below the 6 to the bottom of the 6 is 1 7/8". I can measure the hole, but the reference points are less clear
Sorry, accidental discharge. See next
70Sixter
Mar 15 2008, 11:01 AM
From the left side of the right tail lite to the rt edge of the 6 is 1 7/8" and from the lip below the 6 to the bottom of the 6 is 1 7/8". I can measure the holes, but the reference points are less clear.
If you make the template 914Sixer suggested you should be good.
John
Mar 17 2008, 07:12 PM
QUOTE(70Sixter @ Mar 15 2008, 09:01 AM)
Thanks,
That should get me real close. I don't want to install it where it doesn't look right.
John
