74 914/4 2.0 Original FI. Here's the deal. When I get in the car and the engine cold ( outside temp makes no difference) if I do not hold the pedal to the floor before I try and start the car it will flood the engine with gas-alot of gas, to the point that it drips from the exhaust. Also if I drive the car and let the engine warm up and then let it sit for 30 minutes- it does not matter if I hold the pedal down or not. It will not start for a couple of hour because it will flood so badly. The cold start valve has the power unpluged from it. Any ideas?
Thanks
Paul
