So I took out the new HF leak tester to play with it.
I just put on the 3/4 bank of pistons/cylinder and torqued down the head. Get N03 to TDC. Pull the tester out of the box, and the leak gauge is showing about 40% leak before I even plug it in.
OKay, so I read the instructions, as this looks like it works differently from the last tester that I used.
Directions say to hook it up to the engine. Then depresurize the regulator until the leak dial hits zero. Then it should give me a percentage loss.
Huh? There has to be somehting else I do to show the percentage loss. I have not changed the tool from setting it to zero.
Tool 1, Zach 0
Someone that has used one of these things please pipe in. What am I not doing.
Zach
