So, didn't really get to do much this past week and I went to the Stuttgart Retro-Classics Auto show yesterday, will post another thread with some pictures.
Got back yesterday and decided to put the battery back in. OK, roll her out of the tiny German garage, plop in the battery, hook up negative, pull the positive up to hook it up...WTF? Damn cables just fell out of the terminal clamp!
OK, no problem, lets take a look...crap, the terminal clamp is pretty much toast. Its past 1700 so any store that would have what I need is closed. That just blows.
So I went to the Autocraft shop this morning and after about 1/2 an hour of looking at the beater donated cars and in several bins the manager of the shop was able to find me a brand spanking new one in still in the package! And he didn't charge me anything! On a side note, the bay he found it in was the one that had Scotty's (other mechanic that works there) 69 Camarro Z28 up on the lift and it was almost perfect! Sweet car!
Too make a long story short, I spent about 3 hours re-splicing wires on the passenger side of the car from the headlight compartment to the turn signal and side markers. Also cleaned up both grounds and made sure they were good. Still no headlights and the left side marker and turn signal don't come on. Its not the bulb, I swapped them and they work fine on the other side. The PO did a hack job on the wiring and all the rhino liner crap has all the wires BLACK! I don't know what is what!!
I did check the driver side socket for power, nada, nicht, zilch. So I decided that it was time for someone who knew what they are doing to mess with the electrical issue.
On to pulling out the tank. Easiest thing I have done yet. Unfortunately, in the process of pulling the tank what I believe to be an overflow tube on the brake reservoir snapped off. Picture is attached. The underside of the tank was caked with dirt and I clawed it out of there then vacuumed the area. I pulled the fuel lines that connect to the main line and will take them in to the parts place tomorrow to get some new lines.
My goal now is to clean and rebuild the carbs once the rebuild kit comes in and get her running. Then driver her down to a guy that really knows the 914s here in Stuttgart and have him fix the electrical problem. Once that is done then all I have to do is put in a new exhaust stud, hook up the heat exchanger and new muffler I ordered and she should be able to pass inspection. After that is done I will start working on the little things. I have pictures below so you can see the area under the tank, the brake reservoir (someone tell me if that tube breaking is a BIG issue or not) and the passenger side light motor all nice and rhino lined. Actually the lining is a cheap after market deal.
I do have the heat exchanger parts in the van to drop off at the powder coaters tomorrow. Will have to clean the flapper boxes up myself but the rest I will give to someone else to do.
