I have a 73 with a side-shift. I replaced the bushings about 2 years ago, so they are fairly new.
I was having a hard time getting into first, so I figured I'd do a quick adjustment today.
First is easy, second is now too far over and fourth can't be found.
I put the car in second, go into the cabin and loosen the bolt on the shifter and move the shift level to about where 2nd should be.
Last time, I used this technique and all was good. Now, I can't get to 4th or 5th. I "think" i need to rotate the shaft a little, but I am not certain.
What make sthis all worse is that I need the car for work tomorrow. UGH!!
