Well? Anybody know what the difference is beside hundreds of dollars? Thanks to all who are more knowledgeable than me. Mark D.
Mar 16 2008, 07:57 PM
QUOTE(BMXerror @ Mar 16 2008, 04:12 PM)
if i'm not mistaken, it's the resolution of the signal ... Andy
Rick_Eberle
Mar 16 2008, 08:18 PM
The narrowband pretty much just tells you whether you are above or below stoich (14.7:1 AFR).
A wide band give a continuous range, usually from roughly 10:1 to 20:1.
Dave_Darling
Mar 16 2008, 09:09 PM
The NBO2 tells you just barely enough info to keep a catalytic converter happy. It can tell you if you're richer or leaner than 14.7:1, but not how much. (Yeah, the gauges read in numbers, but they're lying.) You can use this to make small adjustments on-the-fly to keep the catalyst in its best operating zone. That's how OEMs use it.
The WBO2 tells you what your mixture actually is. You can actually use this one to tune with.
--DD
chris914
Mar 16 2008, 09:47 PM
Here are some videos that explains the Narrow band and Wide Band O2 Sensors.
