Hello,
I am stuck. I have a 914-6 that will not start. It was running and started running poorly, and I replaced/upgraded several components.
I am now using:
Brand new: Pertronix coil (3 ohm), Ignitor module (still have the old one.), and a Second Stike digitial control unit. No spark at all.
I have wired out the second strike, hot wired the car directly from the battery to the coil, and strapped the - side to engine ground to be sure it wasn't getting the correct power. (I wired it the regular way, through the harness, I did the above to troubleshoot.)
Any ideas? I have missed two Autocrosses now!
I have checked eveything else also, such as gas to the carbs, and fuel pressure. (Not related to no spark, but just being sure.)
Help!
-- brett
