QUOTE(eresener @ Jan 14 2004, 05:24 AM)
Yesterday I test drove a 73 1.8 w/dual webers...
...have driven my 944 5-speed many wonderful times...
Ok Tell me ....had problems getting into first, crunching gears on shifts...reminded me of shifting an old VW from the sounds I heard...WTF...I expect this is NOT normal...
...if I purchase the car should I plan on replacing all the shift linkage bushings???
a '73 1,8 ? interesting ...
your 944 was -lots- newer when you drove it ...
vague gear selection and crunching may not be 'normal' but they are all too common. the /4 shift linkage is a bit of monkey-puzzle to clear the motor mount bar, although a '73 -should- be a sideshifter which is potentially much better...
wear and DAPO's take their toll... make sure the clutch is adjusted properly. many (dare i say most?) owners have never read the proper procedure and are clueless on the right way. make sure your clutch cable tube is not loose in the tunnel (another common problem). even if everything is -perfect- you're dealing with 30 years of synchro wear. also make sure you have enough of the proper (85W90) spec gear lube - these old transmissions depend on viscous drag to help the synchros work. slippery, thin synthetic is quite the ticket for the new boxes that were designed for it, but a 901 wasn't.
yes, all the bushings ! they lead a hard life in the best of circumstances.
get the clutch adjusted, the oil checked, and the bushings replaced, report back. there are still improvement options open to you but these are the cheap and easy ones.
