Is there some kind of special plug or connection that goes to the reverse light switch on the transaxle? I just got the tranny all back together, now trying to figure out how to wire the reverse switch.
Since this is a custom installation, no existing wiring harness to "reconnect".
Is the switch plug available as a separate replacement part? Doc E recommended just soldering some wires into the switch and make up my own plug - which I'm not opposed to doing but keeping in mind the switch is an $85 replacement part, I don't want to muck it up!
Any other options for hooking up the switch (replacement plug sources, or alternate non-stock solutions)? I just want a reliable connection without dropping a ton of $$!
Jeff
