Threads like this are great...only a few missing instructions however, like .......contort neck into most uncomfortable position.....wish for little girls hands so as to be able to reach plastic nuts.....Have strength in little girls hands equal to Swartzneger(sic)
Oh it is straight forward....but easy only if you are 5' 1" and 150lbs
Ciao
QUOTE(HillKing @ Apr 7 2009, 12:11 PM)
If you look at the picture you can see the nuts where the studs go into the tub of the car. Along the front edge of the car. The vinyl covering is opposite this. I'm told that vinyl (cover) can be removed without removing the dash structure, If you are replacing the other vinyl I would think It would be easier to remove the whole unit. I didn't take this out but there is a bracket in the center (I think) and it my also bolt down on the sides.
